Dear Noggin,
I have a 2 door refrigerator model as above and it intermittently freezes (non frozen goods) food in the lower compartment. I suspect it might be the control unit box situated on the back wall of the lower compartment which sometimes ices up the air-flow flap. Would this possibly cause excessive cold air coming from the freezer down into the lower compartment, as the flap is jammed open due to the ice. Does this mean that the control unit box needs to be replaced. Hoping you can help.
Thanking You
Mick
If the flap was open then truely excessive cold air is coming out/escape from the freezer causing no freezeing. you need to defrost your fridge.
Note also that frost build up increases time to freeze your food on the freezer. it also causes your fridge an increase in electricity consumption.
defrost your fridge for some time ti remove the frost build-up.
Lemmor, we have defrosted the fridge completely numerous times and the problem still persists. Anymore suggestions or advice.
Mick
COLD AIR WILL NOT BLOW INTO LOWER COMPARTMENT, AFTER MUCH REVIEW THE PROBLEM SEEMS TO COME FROM THE ICE MAKER. PARTS NOT AVAILABLE OVERSEAS.
