No buttons work except base setup, speakerphone and ringer volume. I can hear my old greeting but I can't change it.
SOURCE: Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
SOURCE: What's the button on the base to register a handset?
hello Stephwen
On a CD440 base you should see at least a single button wich serves to call the cell phone, for the case when we don't remember where left the device, that's the button that you have to press during 3 seconds. On a CD445 base, you can see more buttons has the images showed on Philips pages... the button as a nice sign on it: it as a point with some curve barsto the rigth side as meaning "echo" or "sound"...
Complements
SOURCE: Uniden cordless phone - model DSS7855
Press and hold "end" and "#" for more than 5 seconds this will de-register your handset without the base unit.
[email protected]
see for more info. http://www.uniden.com.au/RESOURCES_MAIN/pdfs/ELITE8805_OM.pdf
SOURCE: i dont know how to change my greeting,,, on 6.0
You might need your phone's manual to learn how to record the welcome message.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Select model and download manual.
Hope it helps.
SOURCE: how do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
