SOURCE: pool heater cycles on and
Check your by-pass valve to be sure it is closed and forcing water through the heater. Otherwise it will cause cycling and low heat rise.
SOURCE: Our Jacuzzi spa has been running in
Check to be sure your timers and times are set correctly, and check your temp settings and temp you could have a bad temp sensor that is asking for heat and keeps the unit running.
SOURCE: Our pool/spa pump will cut
If the motor is very hot it could be shutting off due to a thermal safety device.
Anything that makes the motor work too hard and/or heat up will trigger this.
Blockage in the water lines
Clogged pool filter
Worn motor bearings
Lack of air flow around the motor
Weak or damaged motor windings.
A defective thermal limit switch will **** off the pump when the pump is within heat and load limits.
SOURCE: spa kicks off in a cycle. needs to be reset
Dean,
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
SOURCE: My jacuzzi magnum force pump is hot is this normal?
the pump is pumping and circulating hot water into jacuzzi, it will get hot. I think it is ok
