Maytag MVWX600XW - Bravos XTM HE Top Load Washer Logo
c
carolyn miller Posted on Aug 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i buy the switch at for a maytag washer lid
LID LOCKS SWITCH LIGHT KEEPS BLINKING, AND CLICKS
Bill Boyd
Level 3:
Top Expert:
  • Maytag Master 53,816 Answers
  • Posted on Aug 10, 2016
Bill Boyd
Maytag Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949148
Points
172802
Any maytag service agent spares or from the manufacturer spares department
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
What is wrong with a washer that fills up with water lid lock clicks but will not do anything else just clicks?
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
2answers
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
4helpful
My washer sensor turns on and then the lid light starts flashing and the washer will not turn on. What is wrong with it?
What is the model number listed on the unit?The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
16helpful
3answers
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
1helpful
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
My Lid on my washer displays open when I close it and won't start if lid is open... please help.
your lid switch is not working or may be jammed try opening the top of the back of the washer make sure the lid switch is working im not sure if the mtw range uses switch or magnetic recognision with switch there is a small lid switch that clicks when the lid is slightly lifted with magnetic it makes no noise however they can both be bypassed by cutting the switch wires normaly black and red running along the right side of the control board (making sure power plug is not plugged in) stripping the two wires and joing them together
this should work
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
