It's a helpful answer. I was looking for it too.
Best,
https://dichvusuatubep.com
First of all, you will require Dry Rot repair: ·
- Paintbrush ·
- Putty knife ·
- Rasp ·
- Sanding block ·
- Utility knife ·
- Wood chisel
Follow below steps:
1. Apply wood hardener and filler
2.Shape and smooth
The process for repairing wood is much the same whether you're using polyester filler or epoxy. Thank you.
Custom Deck Builders Richmond VA Deck Installation By Smallwoodrenovations
Once you have dry rot in a deck it is very hard to stop completely. It is a fungus, and spreads tendrils in the wood grain. Repairs have to involve chopping away all the rot to sound wood, and then treating it. Simply painting it with something s ineffective.
There are many commercial fungicides, all poisonous, so take care. A popular DIY treatment is a mixture of glycol (concentrated auto antifreeze) and borax, with a bit of liquid soap.
There is usually a lot more rot than meets the eye, often in the joists and bearers. The strength of the decking can then be compromised, and if concerned, ask a builder.
You are often best off just ripping out the whole lot, and replacing it with preservative treated timber which will never get the same problem.
