SOURCE: Nordictrack treadmill C2100 belk is not slipping
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: can you get power to a treadmill without the
Hello there. Yes you actually can use a magnet. (thats all the safety key is) It will need to be strong enough to make the switch inside the console activate. I use one from a telescoping magnet used for picking up small screws (available at the big box stores) when I dont have one on service calls.
Just to let you know a refrigerator magnet will not be strong enough!
Good Luck! Tim
