Bed does not respond to remote control .tester shows life on remote .cleaned thoroughly,still nothing,this is why I wonder about a fuse on bed.was working fine ,died without warning.
SOURCE: orthomatic remote
you must open it. and clean the contacts batteries from oxide, dirty, use the plier for to tight the springs contacts. and clean the keypads from oxide, corrosion, dirty, use contacts cleaner. and try again.
God bless you
SOURCE: I can't locate a replacement wireless remote
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: remote control for orthomatic bed does not work
Did you check the batteries? Terminal corrosion? Fuse? Is the motor receiving any power? Control board any good.? Remote good?
