Samsung UN60HU8550 60 Inch Ultra 120Hz Logo
B
Brad Grulke Posted on Aug 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My samsung un60hu8550 has sound but no picture. Just happened this afternoon. Sounds like a t con problem based on searches. Am I right, and how hard is it to replace?
The Vanguardian
Level 3:
Master:
  • Master 531 Answers
  • Posted on Aug 07, 2016
The Vanguardian
Master
Level 3:
Master:
Answers
531
Questions
0
Helped
180443
Points
2974
It could be the t con board, the power supply board, the backlighting, or the display itself.
Don't open it up unless you know what you're doing. There are hazardous voltages even with the TV unplugged!
Testimonial: "Thanks. It turns on. There is backlighting. Hoping its the t con."
  • The Vanguardian
    The Vanguardian Aug 08, 2016
    Actually, the majority of failures I've seen are the power supply board. There are multiple power supplies on 1 board and if the one that fails happens to be the one that powers the t con board then you will see the same failure.
    It's the power supply board that has the hazardous voltages. The rest are safe to handle.
Bad picture on my old Samsung TV - is it the t-con board?
@sam8823 “Now is it possible to damage T con board this way “ absolutely possible. Unlikely that you damaged the panel (sure always possible, but unlikely). “This “Also there were two conductive tapes between Lcd panels (one on left and one on right panel) and TV body. “ sounds odd. Post some good images of your Panel and the cables that enter the panel. Adding images to an existing question that way we can see what you see. You need to have more TABS on a 55” TV than 2. Also, let us know what the exact model is.
This is similar to what you are looking for
2answers
T-con board replacement ?
If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault . Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box.
Sound but no picture on samsung un55j6201afxza
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis.
Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview by mobile or by desktop computer. Mobile View has no search box.
Samsung T-Con Board Replacement
After the T'Con board replacement, some adjustments should be done. White balance adjustment is the main part. To do this, contact any service technician. If you're sound in electronics, you can get details about it be the following links.
Sometimes, a firmware update may be necessary.
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box.
Samsung un60eh6050fxza tv has sound, light in background, cannot see any menu picture when menu is selected, no picture. what board do I need or is it some thing else?
Hi John,
The board that might need replacing is the T-con board but before replacing it, I would suggest to measure the voltage at F301 on the T-con board.
Replacement parts can be found by checking the link provided below:
Search results for un60eh6050fxza
Samsung LCD TV, no picture, but sound and backlights work. Not t-con board. Any ideas what it could be?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
3helpful
2answers
I have a problem with Samsung LN40B530P7NXZA. Powers on nice but 10-15 min later image starts turning white until it turns all white. You can still listen but no image. Help!
This sounds like a defective T-Con board. There is a company that is testing the T-Con board and eventually fix it. They also may offer you a replacement T-Con board if yours can't be fixed. It is a good idea to contact them directly. You can find more details at http://www.coppelltvrepair.com/p/539/repair-service-for-auo-t400hw01-v4-40to2-c02-40t02-c02-lcd-timing-controller-t-con-causing-bad-tv-picture
Samsung hc-r5245w no power
Hello Chac c,
The reason that you are getting a 'red light' is because your lamp is burned out. There is a panel on the back of the TV that gives you access to this lamp. You can remove it and check the part# to be sure then replace it. I did a quick search for you just based on the model# which you provided. You can see it here - http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=samsung+lamp&gg_site=&gg_aid=1295966762
Hope this helps :)
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
