2002 Jaguar S-Type Logo
A
Anonymous Posted on Aug 07, 2016
Hi ,i have s type jaguar. my battery gone flat and i cannot openthe booth at the back ,manualy or by electric. how to open the booth please ..help?
My battery gone flat and I cannot open the back booth to change the battery...anyone know how to open the back booth manualy?? please help
Randy Ohler
Level 3:
  • Jaguar Master 14,585 Answers
  • Posted on Aug 07, 2016
Randy Ohler
Jaguar Master
Level 3:
Answers
14585
Questions
8
Helped
3946099
Points
39683
You can use one of the plugs that go into the power point/cigarette lighter. Cut the end off add wire to reach a good 12 volt battery. Plug it in. This should give you power to open the boot with the switch.
1helpful
I have a 2001 Jaguar S Type in which the battery has gone flat and I cant open the boot to get at the battery to recharge it. Any suggestions.
How about using the key? if not possible then boost the vehicle, you will have a N and P terminals at the engine under the hood, look for a red plastic cap that will be your positive and as for the negtive you can use any place on engine.
How can i get a X Type Jaguar booth to open when the lock thats faulted?
If pushing the button will not open the trunk (boot), you will need to remove the rear seats to access the trunk compartment. Pull the bottom seat off by simply prying it. The fold down back rests are locked from the trunk on top so you will have to unscrew the retaining bolts from the bottom of the back rest to flip the seats up. Once inside, you will find a yellow pull handle that manually opens the trunk where the striker is. Pull it and try to have the replacement peice ready so you don't have to go thru that again.
I have a 2000 Jaguar S-type and my remote key will not work therefore I can not do anything with my car. Please help me.
Hi
Are you sure it is the key causing the issue and not the car's battery? if the battery has gone dead on the car then the remote will not open it. is there any lights on the key to suggest it is working?
Get back to me
Regards
Dan
1helpful
How do you get the boot open on an S type if the battery's gone flat and you want to jump start the car??
There is a small opening between the plate light to insert the key and unlock the trunk even if the batery is flat.
S.Y.
Hi, I recently stated having issued with my jaguar. It is a Jaguar S Type 3.0 year 2000. First the windows from both back doors stopped working they dont go down anymore only the driver and the passengers...
The problem I think is in the fuses. There is a fuse for every electrical stuf and there is for the each door windows. Check wich one is and verfy if is burned.
For the unlocking problem check if you press two times fast the unlocking buton if that will open all doors. Try to turn the key right and hold it for at least 5 sec.
Between the plates lights have a small opening to insert the key and open the trunk.
Try all this. If you don't have a drawing with all fuses check internet.
S.Y.
Battery flat, cannot open doors key not working on
If your key will not manualy open door
Try it in boot lock,it might activate central locking
2answers
2003 S TYPE JAGUAR. DON'T DRIVE OFTEN BATTERY
You must charge the battery or you can use jumper cables from another battery to your battery to activate the electric trunk release, just be sure you hook up the jumper cables correctly ( cable to + on the battery and black to _ terminal of battery)and wear safety glasses when hooking up cables this should release the trunk. Also as a precaution always hook up + or red jumper cables wires first to prevent a arcing spark which is not terribly dangerous but this order in which to connect jumper cables is recommended.
No ignition - jaguar 2 class 2000
something is draining the battery just not sure what,
Jag x type deisel
Hi Wyne
Check all the battery & starter motor terminals, if all OK, a new starter motor will be the answer !
Good luck !
A fixYa rating would be much appreciated Please !
John .
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
