The wiring is not what makes a pump full cycle or circulate. If the spa motor is always on it is either because the pump relay is stuck closed, or the heater isnt keeping temerature therefor requiring the pump to be constantly running. There are also setting on newer style computer boards which determine a pump to be either "jet" or "circulation" pumps.
Also, a spa pump will run fulltime if the water is below 50 degrees F.
If you need further help, contact me @
[email protected]
