This is sort of a two-fold answer, as I am not exactly certain if you are referring to replacing the sand filter media itself or the sand.
Most manufacturers will tell you that the sand filter media itself is a permanent media filter. The only reason to throw the filter away would be after the sand calcifies into a solid block of concrete. The industry has spent 40 years telling the professional industry that sand is forever. Sand media is forever and you never have to change it.
However... this is what Hayward Pools is telling their customers:
On average, sand should be replaced every 3-5 years. The jagged edges of the sand wear down and become smooth as the sand ages. When this happens the sand can no longer trap debris particles and dirt can pass through the sand and back into the pool. As the sand ages, it may start to clump and the water flow can form channels in the sand, allowing the debris to pass through.
I have also talked with several others who believe what Hayward is saying, that basically every 3-5 years it should be changed. We have a strong belief in what Hayward says.
Hope that helps.
Mark
Bath & Spa Parts Online
http://www.bathandspaparts.com
