Could not find the details in TV manual, under Settings-Audio or Settings-Options, or via Google search.
SOURCE: Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
SOURCE: how to disable audio description on LG 32LH3000
First of all, thank you very much George for choosing FIXYA today for your online technical support needs.
See page 136 of the User's Manual for detailed instructions and illustrations on how to disable the AUDIO DESCRIPTION feature on your TV set.
Basically to disable it just press the MENU button on the remote.
Then use the arrow keys to select the AUDIO option.
Then select the AUDIO DESCRIPTION option.
Then use the up / down arrows to toggle the setting to OFF.
Then just exit the MENU.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.lg.com/uk/common/product/support.jsp?localeCd=uk&productId=32LH3000&uri=/uk/tv-audio-video/televisions/LG-lcd-tv-32LH3000.jsp#
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above. Then select OPEN FILE when prompted.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Testimonial: "Thank you very much for your kind help. What happened is that someone had activated the Sap on the Digital Box. Just as you had suggested might have occured. I deactivated that, and now it is working normally. thank you all for your help! George"
SOURCE: Hi I have a Toshiba
Just press the AD button on the remote (below no. 7) I have the same tv and often the kids press this button!
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
I found the fix. Had the same problem.
I right clicked on the sound speaker icon in the bottom right of Windows 7.
Chose Playback Devices.
Once this window opens, then make sure you are on the Playback tab.
Scroll down until you see the HDMI Device. (Mine was hidden at the bottom of the list.)
Then choose "set as default".
The sound will begin playing on the TV with only the HDMI connected......no need for an extra audio cable.
