Built in australia with our commodores
2006 Chevrolet Lumina Royale
cant see any original factory 6 cd stackers for sale in Australia anywhere
better to upgrade to a better after market unit
these CD stacker units do wear out /dry solder /corrosion /diodes
is this the factory cd stacker player that came with that model
..is this unit in the boot
only thing is check all the currents volts to the stacker
make sure the stacker has an individual earth wire
SOURCE: Factory Fitted CD player. 1994 Jaguar XJ6
i think there may be a fuse located on one of the wires thats attached to the radio itself, you will have to pull the radio to check it
SOURCE: 2006 Mazda 6 Power windows and Mirrors not working?
Hi, I have the same problem in my car which is a Mercedes c180 which I might have the solution for the problem. I have traced the problem to the window control module which is found under the interior door panel. you would need to do a test to verify it is similar to my problem. Remove the fuses from the fuse box that corresponds with the windows that are faulty for a few seconds, then replace the fuse which should reset the control module. If it is the same problem as mine the windows will work temporary, which I believe is a faulty window control module. Please let me know how you go.
SOURCE: power lock cd/radio keyless entry not working
There aren't any fuses or relays for your problem, it must be taken to the dealer or other shop that has the special tool to do it to be reprogrammed. It's not a tool you want to purchase for casual use, it's called a "DRB III" and costs around $8,000. I have the directions to do it if you would still like them let me know.
SOURCE: I have Pontiac G6 2006, I have a code P0014,
You dont say what engine you have so I ASSUME its the 4 cylinder??? I dont know what your car needs because I dont know what has been checked, but even the wrong viscosity engine oil or low oil level can cause this code. Or it could be a cam sensor problem. I would have a professional repair shop check it out and recommend repairs.
