The "syntax error" message that you are seeing on your Casio fx-991EX ClassWiz calculator is likely caused by the fact that the calculator does not support the use of decimal values in the exponent. The calculator can only accept integers (whole numbers) as exponents.
To work around this issue, you can try rounding the decimal value of the exponent to the nearest whole number. For example, if you need to calculate 1x10^7.2, you can round the exponent to 8 and calculate 1x10^8 instead. This will give you a close approximation of the desired result.
Alternatively, you can use a different calculator or software that does support the use of decimal values in the exponent. This will allow you to calculate the value more accurately.
The Casios FX-115 ES , FX-115 ES PLus, FX-991 ES, FX-991 ES Plus C can perfom numerical differentiation at a point, and numerical integration between two given limits.
I don't believe I have heard of the model FX910 you refer to. I suspect there is a typographical error: Could be 991. Any way, the FX-991 comes in several "species" and I can only give you the link to the page whence you can download the relevant manual.
Look under the "Scientific Calculators" heading. For each manual, read the whole title because one single manual may do for several calculators.
How about recreating the error and reporting faithfully the error message? You get a syntax error if you try to invert a matrix by using the wrong key sequence such a [SHIFT][MATRIX][3:MatA][X to ] -1), meaning that you use the universal power key on the same row as X squared and log and between them. To calculate the inverse of a matrix, have the name of the matrix on the command line, (see above) then press [X to -1] key one row up from [log].
Concerning your implied affirmation that if the matrix is square you should not be getting any error: You will get an error ( a Math error) if determinant of the matrix is equal to zero.
