I have a POLAROID LCD TV model TLX-04244B. When I press the power button, I can see the Polaroid logo for a split second and then all of the backlights turn off and the screen turns black. When I shine a flashlight on the screen, I can see all images perfectly. Also, the sound works fine. Do you know if this is a power supply board replacement fix? Not sure if it matters but there is a blinking red light on the power supply board. Also, I have visually checked the power supply board capacitors and they all seem fine.
Inverter board failure.
Testimonial: "It is possible to replace just the transformers, or is the entire board typically replaced. With this model, I believe the power supply and inverter board are integrated."
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
