First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Hi Willy, i have the same problem. Im trying to connect my Samsung VP-D361 Mini DV Digital Camcorder to my laptop (Windows 7) but I cant. Is the problem with the O.S driver compatibility?
This is a Firewire cable, also known as DV or IEEE 1394. Sony call it i.Link. It is not compatible with USB and you cannot get a lead to connect it to a USB port. There are converter/adapters that are supposed to allow Firewire to connect to USB but many forum posts say they do NOT work for video transfer. Unfortunately, most Mini-DV cameras will not transfer video by USB cable, even when they have a USB connection (it is usually only used for still pictures).
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you had a desktop PC, you could fit an add-on Firewire interface card to the expansion bus. This will come with a driver for the card.
I have a Samsung Mini-DV, and do transfers with it to the one computer I have that has a Firewire port. It is the only thing I use that computer for, and the reason I haven't thrown it out.
I have a brand new VP-D31. It still has the protector on the screen. I acquired this (legally!) but it has no charger,cables, battery or any etcs. I got it from the Police Auctions and was too ignorant to understand what I was getting. The item was obviously stolen from a store shelf - hence no bits. How about you buy it from me?
For most models, removing the battery pack from the camcorder will restore the default settings; however, some models which contain an EZ Q button, store your settings and removing the battery pack will have no impact on these settings.
The Lithium battery maintains the clock function and preset contents of the memory; even if the Battery pack or AC Power adapter is removed. Removing the Lithium Battery along with the Battery pack will restore the default settings.
* Be sure the battery is connected properly.
* Remove and replace the battery.
* Connect the power adapter and ensure the battery is fully charged.
* * The battery pack may be fully exhausted and require replacement. To ensure the life of your battery, be sure to remove it each time you are finished using the camcorder.
