Intel D945GTP Motherboard Logo
Posted on Jul 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want the Product manual for the D945GTP
I want the Product manual for the D945GTP Motherboard
pogosnip
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 23, 2009
pogosnip
Contributor
Level 1:
Answers
Questions
Helped
434
Points
Http://www.intel.com/support/motherboards/desktop/sb/CS-020725.htm
Anonymous
Level 2:
  • Expert 62 Answers
  • Posted on Jul 18, 2009
Anonymous
Expert
Level 2:
Answers
62
Questions
0
Helped
19884
Points
130
What is manual for Intel D945GTP?
Hello, Tymofii -
Apparently the Intel D945GTP is a motherboard for a computer.
I have not found a manual for that motherboard. Instead, I found technical product specifications for it:
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/desktop-boards/945/D945GTP/D945GTP_TechProdSpec.pdf
It is a PDF document, so you will need Adobe Acrobat Reader software (free). If you choose to download and save the PDF document to your computer, I suggest you give the document a file name you can find again easily . . . something like: Intel D945GTP Tech Specs .
Best wishes.
1helpful
How does the switch wires get placed
On an Intel D945GTP mobo? No prob!
I would like you to download the User Manual, (Motherboard Manual)
This way you will not only have the Front Panel header pinout, you will also have other needed information for the future.
However, in case for some reason you are unable to download the User Manual, I will post the connections also.
[ The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the cables, from the Front Panel go to, is the Front Panel header ]
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d945gtp
On this page under the bold subheading - Documents and Guides -
left-click on the blue -
Product guides for D945GNT and D945GTP.
(Don't believe we can use the Ampersand on here)
On the next page left-click on the blue -
Intel Desktop Board D945GNT/D945GTP Product Guide - English (PDF)
[ Disregard the following if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
{I would suggest upgrading to Adobe Reader X version, if your computer does not have it }
At the top of the PDF file { Header }, is the PDF file page number box.
If you know the page you want, you can use the Down Arrow to slowly arrive at the page you want,
Or,
1) Put your mouse cursor in the page number box. Left-click once.
2) Type the page you want.
3) Press the Enter key
The Zoom In icon ( + ) increase the view size.
The Zoom Out icon ( - ) decreases the view size ]
Go to Page 13. This shows a Top View of the motherboard.
It is clocked 90 degrees to the right, in regards to how it is actually sitting in your computer case. (In your mind turn it to the left)
The letter O indicates the Front Panel header.
Turned as it should be mounted in your computer case;
1) It is a rectangular block with two rows of pins.
2) It is under the SATA headers on the motherboard.
The Front Panel header is color coded.
A) The two pins in the Red block are for the Power On switch
B) The two pins in the Green block are for the Power On LED (Light)
IF, the Power On LED is dim when the computer is on, switch the wires around.
C) The two pins in the Purple block are for the Reset switch, IF a Reset switch is used.
D) The two pins in the Orange block are for the HarDDrive activity LED.
IF, when the harddrive is active the LED is dim, switch the wires around.
E) The pin all by itself next to the Purple block, (Reset switch) is N/C.
Not Connected.
For additional questions please post in a Comment.
Regards,
joecoolvette
Can i use core 2 duo processor with d945gtp mother board?
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Kasun Perera.
Click here for your product specifications PDF document.
On page 10 of the document you will find that the supported processor is that of Intel Pentium 4 Processor in an LGA775 socket.
Therefore Core2Duo is not supported.
Take care!
1helpful
2answers
From which website i can download driver(soundand vga) for intel D945GTP
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+945+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D945GTP
Can I install a SATA 300 HD in to the motherboard D945GTP? THANKS
Yes you can in case if it doesn't detect the entire drive try partitioning the drive below 137gb for each partition so that you can use the entire HDD and all of it can get recognised.
Turns right off when turned on Intel D945GTP Motherboard
Check RAM,OS with working one.
Restore defaults setting by taking out CMOS battery and reinsetion after 5 minutes.
1helpful
945gtp motherboard saported processor
Here you can find them all
http://198.175.96.33/support/motherboards/desktop/d945gtp/sb/CS-026628.htm
1helpful
I want to download driver d945gtp mother board driver for windos xp, does not get currect path help me
hallow there ,,,if you are looking for d945gtp motherboard windows xp and all ,you can download it from this website
http://driverscollection.com/?H=D945GTP&By=INTEL ,,it has all the drivers for your motherboard
Intel D945GTP Layout
No problem M8!
Here you go!
http://www.intel.com/support/motherboards/desktop/d945gtp/tp_manual.htm
Good luck to you!
If you find my answer helpfull, dont forget to vote!
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
