Question about Vehicle Parts & Accessories
Remove interior door panel
How to remove interior door panel
  • Marvin
    Marvin Aug 03, 2016
    Hi Drew
    On a computer?
  • Rod Doney
    Rod Doney Aug 03, 2016
    Vehicle? Year?
    Problem Solver:
  • 9 Answers
On most cars, you have to find any hidden screws in the armrests and remove those. Then if you have electric windows/door locks lift up around the base of them with a flat head screwdriver to get them to pop out and be able to unplug them. When that is done, you usually can just lift at the bottom of the door panel and you will unpop the plastic inserts as you work around the door.
Posted on Jul 05, 2019
SOURCE:
ginko
  • 19396 Answers
SOURCE: Need to replace the driver's door interior door opening assembly
Hi there.
The procedure is roughly the same for all mk3 x types.
You need to remove all the screws on the armrest and on the ashtray, then undo all the plastic clips using screwdrivers on the panel.
You find detailed instructions on links below, I quote:
" remove two screws at the bottom of the armrest.
pull out ash tray.
remove screw in the middle of the ash tray holder.
pull up on armrest, it should pop up, then pull it out
start at bottom right of door and start popping out the plastic clips (all the way around the door)
(remove speaker wires)
push up door panel - done"
WikiAnswers - How do you remove a rear door panel in a Jaguar XJ6
Also from manual:
Disconnect vehicle battery ground lead.
Remove the door trim pad veneer panel.
Remove the upper trim pad.
Remove the door armrest.
From inside the door pocket, release the puddle lamp (1 Fig.1) securing quarter turn fastener.
Undo and remove fixing (3 Fig.1), (front door only)
Carefully release lower trim pad fir tree fasteners.
To avoid damage and distortion of the door metal, lift the lower trim pad complete with clip and clip retainer.
Carefully pull the trim pad away from the door panel.
Disconnect the multi-plugs (1 Fig.2) and remove the lamp.
Carefully displace the trim pad (2 Fig.1) from the door retaining clips.
Disconnect the multi-plugs (2 Fig.2) and (3 Fig.2).
Remove the door pocket.
Displace and remove the retaining clips and remove the trim..
Refit in the reverse order of the removal procedure. Check the trim pad retainers for damage before refitting.
Before refitting the lower trim pad, remove the clip retainer from the pad and and reposition retainer to the door.
ndo door handle escutcheon screw and remove escutcheon
Undo and remove the upper trim pad securing screws.
Remove the chrome strip.
Undo and remove the top channel securing nuts.
Displace and remove the top channel assembly.
Place the trim pad aside (Fig. 1).
Thanks Jaguar XJ6 Interior Lights
I will be grateful if you can rate the solution given.
Many thanks.
G.
Posted on Feb 25, 2009
polarcycle
  • 1392 Answers
SOURCE: how to remove interrior door panel pontiac G6 and replace broken
Remove any bolts/screws you can see then get a plastic crowbar and pry it off. Should have little plastic push pins holding it to door. Make sure you remove all screws though.
Posted on Mar 06, 2009
SOURCE: removing door panel in 2000 toyota corolla
remove phillips scew and the door handle. remove padded arm rest on the door by lifting it up, and remove 2 screws. You can use a panel tool to remove the plastic toggle like pins holding the panel border in. Be as gentle as possible they may break due to becoming brittle.
Posted on Apr 06, 2009
emissionwiz
  • 85108 Answers
SOURCE: how do i remove interior door panel & trim
Answer There is a small black plastic piece that surrounds your door handle. You MUST take that off, I find a small flat tip screw driver works best. The plastic cover that goes on the inside part of the door where your mirror is should be removed, makes it a lot easier to remove door trim: No screws on that part just grab from both sides and pull. 3 screws on bottom and 1 screw inside the armrest. The window crank, easiest way tried and true, shoestring, pull handle towards inside of car until you have enough room to fit the shoestring between crank and plastic washer. Give it a pull back and forth and it'll pop right off; clip should stick to shoestring as an added bonus.
Posted on Jun 01, 2009
  • 1986 Answers
SOURCE: How to remove interior door panel on 2002 chrysler t & c???
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Posted on Aug 14, 2009
How do i remove inside rear door panel on fiesta 2015
Ford Fiesta Plastic Interior Door Panel Removal Guide ...
www.paulstravelpictures.com/Ford-Fiesta-Interior-Door-Panel-Removal-...
Ford Fiesta Interior Door Panel Removal Guide How to take off the plastic interior door panels in a 6th generation 2009-2015 Ford Fiesta to upgrade the ...
Ford Fiesta inner door panel removal (I removed the top one ...
www.fiestafaction.com/.../44959-Ford-Fiesta-inner-door-panel-removal-...
Jan 19, 2015 - 10 posts - ‎3 authors
This is an excerpt from the manual: Remove the rear door window glass. ... Route theinterior door handle cable and door lock actuator electrical connector through the ...Last edited by WildmaninME; 01-19-2015 at 07:41 PM.
Ford - door panel removal - fiesta - YouTube
? 2:19
https://www.youtube.com/watch?v=1URT13Yusjg
Oct 19, 2013 - Uploaded by one2three
this is the removal of a door panel from a ford fiesta 2001. ...Replacing Broken Inside Door Handle on 2007 Ford Fusion - Duration: 5:32. ... Ford Fiesta 1.25 2004 - Cleaning and adjustingrear brake drums - Duration: 8:47.
How To: 2012+ Ford Focus Rear Door panel removal(SE,ST ...
Jan 13, 2016 | Cars & Trucks
How do I remove the driver side door panel on a 1994 Lincoln Mark VIII
Remove mirror mount cover assembly.
Remove inside door handle cup (22634).
Remove door lock control bezel.
Remove window control bezel.
Remove interior lamp lens.
Remove screw from interior lamp assembly body.
Remove screw from window control bezel opening.
Disconnect mirror, lock switches and memory seat on driver side from bezels and wire harness.
Disconnect window switches from window bezel and wire harness.
Lift front door trim panel (23942) vertically, out of weatherstrip and over lock rod.
Disconnect interior lamp (13776) from wire harness.
Remove front and rear door trim retention hooks into door inner panel.
To install, reverse Removal procedure, paying special attention when inserting inner door trim into weatherstrip. Rock inner door trim into weatherstrip and push downward until lower trim belt character ditch lines up with score mark on inner door panel.
Aug 16, 2014 | 1994 Lincoln Mark VIII
2004 honda accord ex how to remove pasenger side front speaker
You must remove the door panel (apply gentle pressure around several points between panel and door, end removal of at least one screw in the inside door handle). Once the interior panel is removed, there are several screws holding the speaker in place. Remove these screws and the speaker (once disconnected from the wiring) will come out.
Jan 15, 2014 | Vehicle Parts & Accessories
Remove interior door panel on a 2008 mercedes benz r350.
how to remove left front door panel of merc.2008 220cdi
May 01, 2012 | 2010 Mercedes-Benz R-Class
How can i remove door skin on '97 dodge caravan mini van to repair power window?
you don't remove the door skin, you remove the interior door panel. Find and remove all screws in door panel, they will be located under panel, behind interior door handle, armrest area, you might have to remove plastic plugs that have screws behind them. Panel will have plastic clips all around perimeter, panel will pull towards you from edges to release these clips, lift panel up and it will come off. You will have to disconnect any wiring. now you can get into the door to get to window regulator and motor.
Apr 07, 2010 | 1997 Dodge Caravan
Interior trim panel removal instruction
Normal 0 . Disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
If you don't have power windows you will have to remove the manual window crank. It is held in place by a clip on the back side of the base. To remove the clip, you will need a small hook (kind of like a knitting needle). Put the hook in behind the base, and grab the clip and pull it off. To replace it, slide the clip back on the window crank, and snap it back on the door.
May 31, 2009 | 2003 Volkswagen Passat
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
How to remove interior door panel on a 1997 caravan with ower windowq
Start by removing the negative battery cable from the battery. Then locate and remove the screws that hold the interior door handles in place (they may be hidden by snap in, or snap on covers). Once you have removed the interior door handles, disconnect the wire clips that go to your window and door lock controls.
I personally use a small pry bar to remove the interior door panel; it is held in by plastic snap clips. Try to get as close to, or directly under the snap clips as possible with your pry bar to prevent them from tearing out of the door panel. Once you have released the snap clips, pull the panel upward to remove it. Install in reverse.
I hope this information helps you, and I wish you luck on your repair.
Apr 24, 2009 | 1997 Dodge Caravan
How to remove the door panel on a 96 Ford Thunderbird?
Carefully pull front door trim panel finish panel away from front door trim panel.
Disconnect wires from front door lock switches, outside rear view mirror controls and window regulator control switches, if equipped. Remove front door trim panel finish panel.
Rotate top of front door trim panel away from front door and lift bottom hooks from front door.
Feb 21, 2009 | 1996 Ford Thunderbird LX
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
