Hi all,
This is a similar problem but the fixes listed to date have not worked for me.
Problem: Incoming faxes show 'receiving', but fail to print.
Relevant info:
(*) Receive mode is set to 'Fax'. (In the Fax mode, the machine answers an incoming call and immediately goes into fax reception mode).
(*) The toner is not showing 'low' or 'out' and the printer continues to print perfectly.
(*) Just to be sure I set the New Toner to 'Yes' as suggested in this log.
(*) I have also downloaded and installed the latest device drivers from Samsung.
Is there anything else I can / should try?
thanks ... PeterF
Hi Regchandra ... not sure what you mean by main board. The printer is quite new and is absolutely "out of the box" standard.
I have completed some more tests since I logged the problem. The fax neither sends nor receives. in both cases I can hear the fax "trill" from the remote fax, but mine does not respond.
Any other suggestions (other than returning it for repair)?
thanks Ha1ku
This is now fixed. It was an intermittently faulty USB Connection.
thanks for your interest.
