There are two main caused of blank printouts in inkjet printers: Low ink level Clogged nozzle of the ink cartridge Refer to this article: Blank Page while printing
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Remove the toner and wipe the small window that's above where the drum unit sits inside. That window gets covered with toner and makes light prints and blank areas.
Recalibrate the Printer Recalibrate the Media Sensor of the printer by pressing photo and cancel buttons simultaneously make sure to load one piece of 8.5x11 normal white paper Print demo page If the printout is still blank call the technical support with the number 18004216699
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
