Reporting someone to hasbro interactive for copyright infringement. There is currently a Kickstarter for a mech game called Mech Command RTS which I believe infringes on the "Mech Commander" IP. Just looking for a way to let someone from Hasbro Interactive know about it so they can see if anything needs to be done about it.
SOURCE: Error Report (send-Dont send issue)
You turn error reporting off.
You need Administer privileges to do this.
1) Right click My Computer
2) Click on the Advanced Tab
3) At the bottom right of the resulting property sheet click on Error Reporting
4) Select Disable Error Reporting and deselect 'but notify me, etc.'
This is a persistent setting unless you "Reinstall your OS" in that case you will need to do steps 1-4 again.
Restart your system.
You should be able to run the game at any configuration you want. Take a look at the settings in the game to see if it sends you error messages but I bet you've done this already.
As always make sure you are using the latest set of drivers, not Beta, for your Display Adapter.
Regards,
Worldvet
SOURCE: is bundled product key an infringement of privacy?
Why would it be an invasion of privacy? You do not need to give any personal information when you activate the software and you can put any or no information in the registration information. You can also activate via telephone if you wish
Testimonial: "thx alot "
SOURCE: i don't know how to use the interactive blend tool
You can use this graphic as most suitable shapes and you can draw any thing as any structure you have in mind.
