The following ink cartridge appear robe missing or damaged . Refer to printer documentation. This happened right after a paper jam.
I cleaned the paper jam and had a hard time putting the back portion back in. So I kept having a blank page . Them finally I was able to print one page and the message appear. I was able to print the extended self test after reset by pressing ok+cancel+black
It states: " Ink cartridge problem Cause The indicated ink cartridge(s) are missing or are damaged. Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP customer support." Go to: www.hp.com/support Basics Guide 29 Troubleshooting and support
Resolving a blinking light
When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear.
The following table lists possible causes and what to do to correct the problem.
SymptomPossible causeWhat to do to correct the problem
Power light is blinking
Printer cover is open
Close the cover.
Printer is out of paper
Insert appropriate media in the In tray.
Printer has difficulty picking up label media
Change the printers print mode setting.
Change the printer's paper type selection.
Use a different brand of label media.
There is a paper jam
Follow each of these steps until the problem is resolved:
Remove the paper from both paper trays.
Press the Power button once. Wait a moment for the paper jam to clear.
If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
Remove the rear access door.
Remove the paper jam through the opening at the back of the printer.
Replace the rear access door.
Reload the paper into the paper In tray.
Print the document.
There is a problem with a print cartridge
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout
The print cartridge has partial loss of electrical interface with the carriage connections
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
EUREKA!!! I HAVE FOUND IT!!! After running into repeated failures after attempts to clean electrical contacts, I finally figured out that the issue could be due to how the cover was seating above the ink cartridges. So by "jiggling" the cover while opening and closing the cover, I was finally able to remove all of the warning messages and be cleared to print. This insight should be useful to many people who have made the wrong presumption about the root cause of the problem, only to solve it accidentally after opening and closing the printer cover multiple times after reseating ink cartridges.
