Gzipwtf.comhttps://gzipwtf.com > Helpful tips
Sep 9, 2019 - A PF (Power Failure) error code indicates that the drying cycle has been interrupted by a power failure. Touch and hold START to restart the ...
Really need make and model (what it is) in questions like this!
A P6 error code occurs when the pressure of the system goes below a certain value. This is caused when the pressure of the system is too low for the unit to operate. ... If the pipe isn't hot, then the system is low on refrigerant and there could be a possible leak somewhere.Mar. 25, 2021
A P6 on a Carrier air con means a communication error between the inverter and power supply PCB on the outdoor unit. In most cases, both boards will require changing. Check with a Carrier Agent first. I can imagine that replacement of both will be a costly exercise.
If this is occurring on windy days, a back draft in the flue termination is blowing the pilot out. When this happens ,everything shuts down, as it should. If it occurs under all weather conditions, the air filter may need cleaning. Also, be sure that there are no obstructions blocking the air louvers on the front of the heater.
To assist you further, I have included a link to the owner's Manual for your model, in case you have misplaced yours. You may download and print this manual if you like.
Paul, the Error Code Fault 13, indicates a Combustion Control Fault. This could mean, not enough gas for safe combustion or to much gas for continued operation. In any event, if requires a service call from an authorized Rinnai Service Technician to solve.
Just in case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference.
