Cell Phones Logo
Vic Hartounian Posted on Aug 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I turn on Blue tooth on asus f102 b note book
A.P.Gokul poominathan
Level 1:
New Friend:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jan 15, 2017
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
16
Questions
0
Helped
26633
Points
39
It is available in settings or go to the search option and type bluetooth
shadow
Level 3:
  • Master 490 Answers
  • Posted on Aug 01, 2016
shadow
Master
Level 3:
Answers
490
Questions
0
Helped
217679
Points
1613
Hi Vic,
Step 1Push the wireless button, located on the palm rest or on the front, right or left side of the ASUS notebook or netbook. The Bluetooth icon appears on the screen, indicating that it has been activated.
Step 2Alternatively, press "Fn-F2" until the Bluetooth icon appears on-screen.
Step 3Alternatively, expand the system tray and then double-click the Wireless Console icon -- the blue and white icon with the "i" symbol positioned in the center. Click the Bluetooth icon to activate Bluetooth on the ASUS PC.
How do i connect Asus tablet to chromecast
If it is suppose to connect with wifi then make sure in settings that your wifi is on in our tablet. Or if it is suppose to connect with blue tooth then make sure your blue tooth is on in your tablet.
I have HP Pavilion DV6 model no WW146AV.How to activate bluetooth in this model
If your particular model of HP has the blue tooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the blue tooth, as well as the wireless LAN. A blue tooth icon should appear in your task bar near the clock when blue tooth is turned on. ELSE
You have to go into start, then all programs, then look for the blue tooth connection setting. Hope this helps.
Go into start, then all programs, then look for accessories, the find blue tooth wizard. You can switch it on via that.
NOTE : BE SURE THAT YOU HAVE A BLUE TOOTH IN YOUR MODEL BECAUSE SOME OF THE MODELS DON'T HAVE IT.
I have to activate bluetooth in my fujitsu note book how can i acctivate.........
The Fujitsu AMLO Pro, by default doesnot have a blue tooth adapter . If you have ordered the blue-tooth card in the laptop when you ordered then you can switch it on using the wireless key button on the laptop. However if you have not ordered a blue tooth card with the laptop. You can purchase an external USB blue-tooth adapter.
The user manual for you laptop is on the link below for reference
User manual
Thanks for using Fixya
Proton
I have a asus T3200 Cant make blue tooth work
normally this model not contain the blue tooth adapter or card only supply the software for it. so you have to buy blue tooth adapter or card separately.
1helpful
I have a blue tooth by plantronics. Dont know how to hook up with my samsung myshot. I dont have book on bluetooth.
try this, turn on the blue tooth of your headset and then go to the Bluetooth settings of your phone, search for the headset, once paired for sure that it will ask for a code just enter 0000, that is the default pass code for that.
1helpful
I need help to turn on my blue tooth..please
You probably need to use a function key to start it up ? go to asus site and find the function key that supports blue tooth . ie : F 2 - OR F 3 ...ECT
Wireless radio adapter or card
Try:
G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2:
1st press: On both Blue Tooth & WiFi
2nd press: Off Blue Tooth / On WiFi
3rd press: On Blue Tooth / Off WiFi
4th press: Off both Blue Tooth & WiFi
Blue tooth
Hai,
Yes, u can use bluetooth device on ur PC.
Purchase one USB bluetooth adapter from any of the nearest PC dealer. It includes a CD to install. Connect, install and enjoy
good luck
Rabby
Top ASUS Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you an ASUS Cell Phone Expert? Answer questions, earn points and help others
