Question about Korg Pa800 61-Key Pro Arranger w/Spkrs
Can not loading factory resources - Korg Pa800 61-Key Pro Arranger w/Spkrs
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Why Play Store Forever Loading ?
Try going to:
Settings > Apps Manager > PlayStore. From here tap Clear Cache and clear Data, reboot your phone.
if it still doesn't work, you could try to uninstall updates, same procedure as above.
Your last resource, in case nothing else works, is resetting your phone to factory settings. Every phone is different, so must search for it. Type "How to hard reset ZTE Score".
Jun 06, 2014 | ZTE Score
Factory reset korg pa1x ?
To factory rest on Korg pa1x you should take few steps and as a warning i have to say you will lose all your existing setting and data.
First download the operating system version 3:01 into four floppy disks. you can find it for mac and PC versions.go to http://www.korgpa.com/support/discontinued-products/korg-pa1x-pa1x-pro.html
Second: if your Pa1x has Hard drive transfer the factory resource file from the above link into hard drive.otherwise you need to copy factory resources to FDDs again.
Third: turn off the Keyabord and insert the FDD1 into floppy drive. once you turn the keyabord if you press intro instead of OK it will wipe all the OS and setting on your keyboard and then start installing fresh Operating system.
Fourth: turn off and on the keyboard. then go to this and go to utiliy and find your HDD and load the factory resource. I mentioned if you don't have hard drive then go to FDD and insert the FDDs for factory resources and load them one by one. then turn off and on the keyabord.
All done.
Regards
Arash Armand
Sep 04, 2013 | Computers & Internet
Con I restore my HP M8200n to factory specs?
Sure if you have the restore disc if not you can get one from the factory. Or a Windows Operating System disc will also work as well. You will have to download driver files if your using XP disc. Win 7 works great for this type of situation loading drivers is easy with Win 7 recommend if you have the resources to handle it. John
Apr 19, 2012 | HP PAVILION M8200N PC Desktop
I want to restore my PC to factory settings. How?
Hi avidriving,
Please follow the Instructions:
Step 1: Click "Start" menu. Step 2: Click "Programs." Step 3: Click "Acer Recovery Management." Step 4: Click the "Restore" button on the bottom of the dialog box that opens.
Step 5: Click "Restore System to Factory Default."
Step 6: Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7: Click "Start" to restore the computer to the default factory settings
Tips & Warnings: If you are unable to access the Start menu, use the recovery CDs that came with the computer or visit Acer's website (see Resources below). Always make a back-up CD before restoring a computer to factory defaults. Resources Acer Website.
Hope it helps.
Thank you for using fixya
Oct 14, 2011 | Acer Aspire G600p PC Desktop
Reset printer
Please print printer settings configuration page. The page will explain the printer menus and change values. Menus are represented by Continue, Ready/Data, Toner Low and Load/Remove Paper light sequences. Menu Items and their values are indicated by Paper Jam and Error Light sequences
Here are the instructions to do that:
1. Turn off the printer.
2. Open the front access cover
3. Press and hold the red Stop button while powering up the printer.
4. The lights should cycle, release it when the light stops cycling.
5. Close the cover once the ! light displays
6. The lights should cycle again.
7. Then press the Continue button.
8. This should print a Printer Diagnostics page.
9. On the Printer diagnostic page, Use the Utilities menu to troubleshoot printer problems
- Return the printer settings to factory default values.
- Sometimes resetting the printer to the original settings solves formatting problems.
- All menu items are reset to the factory default values except:
- All settings in the Parallel menu, Network menu, and USB menu.
- All downloaded resources (fonts, macros, and symbol sets) in printer memory (RAM) are deleted.
- Resources in flash memory are unaffected.
10. Please locate the value that would say "Factory Defaults".
11. We would need to follow the exact light sequence that you see for the "Factory Defaults".
12. Press and release the Cancel button to advance through the menus and the menu items to the one we would need.
13. Press and hold the Continue button until all the lights cycle to save the function/value.
14. Restart the printer.
Jun 16, 2011 | Lexmark E260dn Laser Printer
I have an Acer Aspire 5520-5334 how do i reset to factory settings? It is running window vista.
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Click "Start" to restore the computer to the default factory settings.
Tips & Warnings
Resources
Feb 06, 2011 | Computers & Internet
Windows won't load, it keeps looping back to
Tell your boss to give you the factory disks, you need them. Your Windows install is corrupt. Trust me, I've been doing this since Windows 3.0.
Oct 21, 2009 | Toshiba Computers & Internet
Korg Pa800 61-Key Pro Arranger w/Spkrs Logo
291 people viewed this question
Top Korg Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Korg Audio Player and Recorder Expert? Answer questions, earn points and help others
