Question about Lexicon Computers & Internet
Haven't used my lexicon omega in years,cant find the serial number.is there away to get it from Lexicon? Or any other place?
SOURCE:
SOURCE: Device is unrecognised always day per day
I've been struggling with this issue for about a week. My unit was locking up increasingly more often.
Two things I've noticed about my Lexicon interface:
1. Seems to be excessively hot.
2. The unit is not vented.
Yesterday, after reading a comment about the solder possibly being the problem, losing conductivity as the units warms up. I decided to run my Lexicon with the plastic case removed.
Since removing the the case, i have only had one instance where the sound stopped working, which i believe was a problem with Cubase in that instance.
I'm not sure if removing the case to keep the unit cooler is the solution. I may have improved a connection somewhere in the process of opening up the unit.
I can say that I went from getting a "new hardware found" message every two minutes to having virtually no problems since removing the case.
My next step will be to drill about 50 holes in the case to vent it before attempting to use the case again.
Best of luck to ya!!!
Posted on Jan 25, 2008
SOURCE: Blue Screen of Death when running MIDI input to Lexicon Omega
I tried the above - works perfect!
Thanx lumps...
Thomas
Posted on Feb 07, 2008
  • 53 Answers
SOURCE: Lexicon Omega USB on new HP Dual core laptop pc running vista 4GB Ram
You said the magic phrase premiume HOME computer...
and the key word VISTA.
I've heard of VISTA pro running this but the home version is really not that robust for the type of gear you have there.
vista just has to many bugs.
go back to xp pro sp2 for good results.
good luck
44hink
Posted on Jun 12, 2008
SOURCE: lexicon omega driver
Yes having the same problem with new driver that Lexicon put on their site 2.5 driver has screwed up everything and the soundcard is nolonger working because of this new driver even their website is down very poor avoid Lexicon Omega
Posted on Aug 09, 2008
  • 3 Answers
SOURCE: Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Hello i opened my lexicon omega and the cd wont download, i have tried a number of things but it keeps coming up with stienberg softwear, i have registered but the lexicon omega will still not load onto...
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
Apr 16, 2011 | Lexicon Omega Desktop Recording Studio
How I can to installer a sofwer compatible to windows vista? for lexicon omega studio
at first resistering your product. then you download your vista driver on lexicon website; thanks
Apr 09, 2010 | Lexicon Omega Desktop Recording Studio...
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
Feb 28, 2009 | Lexicon Omega Desktop Computer Recording...
Lexicon omega driver
Aug 09, 2008 | Lexicon Omega Pro Studio External Sound...
Nov 06, 2007 | Lexicon Omega Pro Studio External Sound...
One day I turned it on, loaded the software. Error message...
This product is JUNK. An associate of mine advised me to purchase this piece. It worked less than six months. Now the unit is fourteen months old. Lexicon said they'd be happy to have me return it along with a money order, certified check or credit card number because the charge would be $75.00 flat to either repair mine and send it back to me, or replace the entire unit.
The associate who advised me to purchase this piece of gear works on microcircuits each day in his line of work. He uses microscopes to examine his work. One day when his Omega quit working, he opened it up on his bench where he identified numerous cold-solder joints. He repaired them and the unit worked for about three months before becoming unstable. He opened it up a second time and noticed all the jacks were starting to get loose.
At that point, be became aware of the $75.00 option with Lexicon. Instead, he deposited his Omega into the dumpster behind his place of employment. Today, his unit is a part of the landfill in Dallas, Texas.
LEXICON ABSOLUTELY KNOWS ABOUT THE PROBLEMS WITH THE OMEGA. LEXICON SHOULD REPLACE THE UNITS AT NO COST; CONSUMER PAYS SHIPPING IS FINE WITH ME. TWENTY YEARS AGO, LEXICON BUILT RUGGED AND DEPENDABLE GEAR. IT IS TOO BAD THEIR FINE NAME IS ON SUCH A PIECE OF ****. I'M AFRAID I'M DONE WITH LEXICON, FOREVER. IT WOULD BE TOO DIFFICULT TO CONSIDER PURCHASE OF ANYTHING WITH THE NAME ON IT.
Nov 05, 2007 | Lexicon Omega Pro Studio External Sound...
Computers & Internet Logo
205 people viewed this question
Top Lexicon Computers & Internet Experts
Tony Raia
Alun Cox
Thomas F. Schneider
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
