Re: Serial number 112Km00462. If overheated and power...
The magnetron thermal protector probably shut the oven down. Magnetrons don't like it when their load impedance is too low (empty oven or popcorn) and they get quite warm. Operating an oven empty also shortens the life of the magnetron.
The magnetron thermal protector probably shut the oven down. Magnetrons don't like it when their load impedance is too low (empty oven or popcorn) and they get quite warm. Operating an oven empty also shortens the life of the magnetron.The magnetron thermal protector probably shut the oven down. Magnetrons don't like it when their load impedance is too low (empty oven or popcorn) and they get quite warm. Operating an oven empty also shortens the life of the magnetron.
You can't post conmments that contain an email address.
If your LG Solardome microwave oven is overheating a melamine plate within 30 seconds, there could be a few potential issues at play:
Power Settings: Check to see if the power settings on your microwave are too high. If it's set to a high power level, it can cause certain materials, like melamine, to overheat quickly. Try reducing the power level and see if that helps.
Plate Material: Melamine plates are not suitable for use in microwave ovens as they can overheat and potentially release harmful chemicals into your food. It's recommended to use microwave-safe dishes made of glass, ceramic, or microwave-safe plastic.
Microwave Performance: If the microwave is consistently overheating items within such a short time frame, it might indicate a malfunction. In this case, it's best to contact LG customer support or a certified technician to inspect and repair the microwave.
Placement and Usage: Ensure that the plate is placed centrally on the turntable and not touching the sides of the microwave. Also, avoid using the microwave for extended periods without interruption, as this can cause overheating.
Testing with Different Materials: Try using a microwave-safe ceramic or glass plate to see if the issue persists. If other materials heat up quickly as well, it could indicate a problem with the microwave itself.
They are usually at the rear where the power lead goes in. This will state the maker, the address, the voltage and watts, the model number and serial number. That is a statutory requirement. In some circumstances they are in the door frame rebate but not so common where heat is involved.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Microwave.
The "H97" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and Panasonic customer service to find the proper part for the microwave.
Unplug the microwave and plug it back in after 30 seconds to make sure the message did not appear because of a simple glitch. If it does not come up again, use the microwave as normal.
The "H98" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and customer service to find the proper part for the microwave.
Your microwave comes with a warranty that will cover the inverter if the warranty is still valid. Call the number for the warranty department or bring the microwave, with receipt, back to the store you purchased it from. This will save you the hassle of replacing the par
The door safety switch may be defective. But need a model number to be sure, here is a web page that you can go to insert your model number and it will give you a parts break down once you have that get back to me for testing instructions.
It's cooking when it shouldn't, but the internal cooling fan is not running, so the magnetron is overheating, which can kill it.
Then when it gets hot enough, it trips the magnetron's thermostat, interrupting all power to the microwave. When it cools, it comes back on.
If and when an oven is coming on or doing anything by
itself, this is very dangerous and can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and of course one should never leave a microwave unattended while cooking.
The problem is almost certainly that the power relay on your control circuit board is shorted.
We regularly repair such control
units for
customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
free information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
If it goes dead for a
while during or after cooking
then comes back on, the magnetron is probably overheating and causing
the magnetron thermostat to open.
Then when it cools, it
closes the circuit and allows power through again.
An overheating magnetron
can be due to:
operating
oven without cover(s) in place
wrong
magnetron installed in oven
an old or
otherwise failing magnetron
cracked
magnetron magnet
improper
power line voltage (US homes should be 110-125VAC)
foods low in
moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear
oven)
failed or
inoperable cooling fan or hood vent exhaust fan
deteriorating
foam weatherstripping seals in air ducts or on outside cover
blocked air
vents (dust, animal nest debris, insufficient free air space behind
& around oven, etc.)
clogged or
greasy charcoal filter or grease filter
blocked duct
in hood vent exhaust
I would suspect a failure or the fan, clogged filter or bad magnetron.
You didn't mention your brand or model number, so I'm limited to general advice. You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're
