Call the toll free number on your prepaid airtime card, follow the prompts to talk with a live rep, they will need the numbers under your phones battery ESN NUMBER, OR IMEI which you can get by opening the dialer and enter *06# and call button, you will also need to provide the prepaid card number when asked. Good luck
you must have a leak somewhere. Your coolant will not boil unless you have a leak. Check for leak traces of fluid the color of your anti-freeze. Your radiator cap is spring loaded and with time the spring gets weak. Check that area for leak traces. The easiest way to check for leaks is to look at your driveway. if you have a coolant leak the fluid traces will be on the driveway. Don't mistake your air conditioner water leak as being the coolant fluid. The anti-freeze coolant has a sweet smell whereas the air conditioner fluid is just plain water being removed from the air inside of your cab.
There is aa line coming off air compressor if you trace it down there are two valves on it was screw on caps. The smallest valve is where you hook up freon hose to add freon. I hope this helps, any clarifications needed fell free to ask.
Katie
Please remove the battery immediately and he SIM and memory card. Use your hair dryer to blow cold air into it for a long time. Till you are sure that there are no traces of water inside. Then re-insert all the items removed and power on the phone after a small prayer. Hopefully it should work.
Mind you. it is cold air and NOT hot. Hot air will definitely burn the phone's internals.
Remove battery immediately.
Use your hair dryer or such device to blow cold air into it to dry its internals. DO NOT USE HEAT. blow air a long time. When sure of no traces of moisture inside, insert the battery and power on.
With the heat on, you may have burnt something inside. Whenever you get your phone wet, always remove the battery and SIM immediately and use the hair dryer without heat. Just plain dry cold air. Blow air into it for a very long time to remove all traces of water. Then power on the phone. It may work. You still may have a chance to save your phone. Do blow air through the phone.
It sounds as if you have a leak in your ac system. There are kits that allow you to add ultraviolet dye to the system. After running the system you can trace the dye to find the leak. In your case I think you could locate it in a day or two. Once found, repair the leak and evacuate and charge the system. I highly recommend having a vacuum pulled on the system since it has been low numerous times.
Good hunting
it is possible to trace but it is very doubt to do coz it will give u only the plaze where it have but the place can be change coz it depend on mobile and it will take u lots of time
