The printer is showing message "Unable to print 4F"
The printing process is blocked by a system problem, indicating the Brother Printer In Error State Windows 10. Normally, this problem is caused by system permission settings, corrupted drivers, or system conflicts.
Solutions of Brother Printer In Error State Windows 10:-
1. Make ports settings changes.
2. Make sure that your printer is Online.
3. Reinstall the printer driver.
4. Set the Print Spooler service to automatic.
5. Update Windows.
If the problem continues, check this blog or call Printer Support to stop more printer damage.
Solution with Expert Advice- Brother Printer In Error State Windows 10
Defective scanner you must change scanner or replace motor inside in scanner.
SOURCE: Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing.
thanks
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: brother mfc5860cn has error message print unable - 4F
Hi there
Please try this.
SOURCE: Brother MFC-3360C error message ''PRINT UNABLE 4F .....''
Hi there
Brother 4F is this have a go it could work for you.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
