PROBABLE CAUSES:
1. Failed T/S corona.
Remove the T/S corona unit. If blank copies can be printed without a service code appearing, replace the T/S corona unit (p/n 57AA R715 00).
2. The HV unit has failed.
Replace the HV unit (p/n 56AA 8401 2).
From the Canon forums:
To try and resolve the 5200 error, please unplug the power cord from the back of the unit and leave it out for at least 10 minutes, then plug it back in and turn it back on. If the error persists, the unit may require servicing to resolve the issue. Please click on the Contact Us link below to obtain further assistance and servicing options if needed.
This didn't answer your question or issue? Find more help at Contact Us.
just to be sure this is a gas fired furnace? - what make and model?
behind most not all are sensors behind or near the blower fan - these little buggers are easily missed if you have one - jumper the wires and see if it fires if it does this sensor need replacing -
When you open the door on the right side on the door is a assemble that has paper guides cover to very find wires, that assemble is either bad or the wires in the assemble are bad, have a tech look at it might require replacement.
y you want an activation code when you can edit the host file saved in adobe photoshop and have it working freely.. Follow the steps below
open your browser go to : http://thepiratebay.org/torrent/6439143/Adobe_Photoshop_CS5_Extended%28Crack%29_Instructions-ANM
Copy the link in your browser and download it via Utorrent and its 100% safe and virus free its 2.15kb its a host file that you going to use to make your Adobe photoshop free and you even got the how to instructions in it..
This code should clear by turning off then on the machine. If that does not work then you will have to check the High Voltage Charge Corona. Has the drum unit been recently pulled out? If so check the Charge Corna housing is it properly installed.
This could be a capacitor if your lucky but can also be the horizontal transistor. The repair could cost you between 60$ and 150$
My opinion; it's not worth it.
