Try leaving the key in the ignition (but don't turn it) and then try. If it starts then you need to properly bypass the transponder system. If not then most likely you don't have your ignition and/or start wires hooked up properly. On many cars there is a second starter wire that needs to be connected
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Sounds to me like you have a broken linkage from your ignition tumbler to your ignition switch. It is a plastic "arm" that pushs.pulls a metal tab on your ignition switch.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
does it click or grind when pushing window button if so the window lift track may need replaced, if there are no sounds then disconnect the wires from the lift motor and with the ignition on so power is sent to switch, push button and check wires to 12 volts dc. If no power I would replace the driver side switch after checking the wires for defects. If there is power then I would re-install wires to motor after turning off key and try button again with power on. replace motor if it doesn't work.
They have a bad ignition problem. Its more than likely the ignition. Turn the key on, Then right below the ignition theres a hole. take a long skinny phillips screw driver and push it up through the hole and you will hit a release for the ignition. Push it up as you pull the ignition out. Then try to start the car with a flat head screwdriver. Write back if that doesn't work but i have a feeling it will.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the push button igniter next to the burner control knobs on the front of your grill. Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the grill has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck
