Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
