Bulova Crystal Ladies 96T63" Logo
Neisy Montes Posted on Jul 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which battery number should I use on a bulova 96t63
Which battery number and brand should I use .
Joseph Coppeto
Level 3:
Master:
  • Master 360 Answers
  • Posted on Jul 28, 2016
Joseph Coppeto
Master
Level 3:
Master:
Answers
360
Questions
0
Helped
150074
Points
2623
Most likely...
Bulova 228 = S05 American Watch institute, USA: 357 (303)
Japan: SR44W .. (SR44SW)
Possibly...
Bulova 606‎ = S32 AWI... Energizer/Duracell 377 or SR626SW
Which battery number may use in this watch bulova 96t63 thanks
and
Specialty Battery Finder
Battery size for bulova 98g48
If there is a dead battery in the watch, when it is opened, that is one way to identify the battery size.
A second way, if no battery left in it, is to go to a local jeweler or watch battery replacement kiosk at the shopping mall.
Third, contact Bulova at phone number shown:
https://www.bulova.com/pages/manuals-parts
Parts Manuals
2answers
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
New watch bulova 96R-19 women, and dont know how to start...
I have read the instruction for this watch and I am surprised how little they tell you!
The description of the watch does not say if it is automatic or battery driven so I shall give you two alternatives to try:-
1) If it is battery driven, then there may be a wedge under the winder to prevent it going into the running position (to save the battery while it is on the shelf). Pull this out and push the winder home.
2) If it is automatic, then it is mechanically driven by a spring and needs to be wound up. This is done by either turning the winding knob or gently shaking it from side to side form some minutes. Once going, such a watch needs to be worn daily to keep it running. They will normally run for 1 - 2 days before stopping when not being worn.
If you were not given instructions with your watch, you can get them from their web site http://www.bulova.com/brands/bulova/product.aspx?origin=sku&sku=96R19&brand=bulova.
2answers
I received a new Bulova Marine Star Men's watch but lost the manual. I need to download a manual. My model is goldtone adjustable band with black coated center line. Besides the clock it has 3 other...
If you go to the Boluva web site http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine Star&gender=1 you will be able to find your watch on their list.
Click on your model and you will see a page with information on the watch which includes operating instructions which you can download.
Dec 08, 2010 • Watches
1helpful
Just replaced the battery on the Bulova Ladies bracelet watch. watch keeps stopping still.
If you have had your watch awhile, it probably needs a clean/oil/adjustment. FIne watches need regular mainentance just like a car. Take to a local watchmaker or send to following:
http://www.bulova.com/service/servicecenter.aspx#inside.aspx
2helpful
Bulova automatic How old and value.....number 3865924
To get exact age and price, follow this link:
At the bottom of page you will find CONTACT US. Just click on it .
Rate me, please.
2answers
Need operators manual for a bulova marine star 90A07
While I can find "Marine Star" in the list of models, I could not find one with the same refernce number.
There are a number of models so if you go to http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine%20Star&gender=1 ", you may be able to find one that looks like yours.
If you click on a watch, details appear and these include operating instructions.
Adjusting the band on a boluva 96T63
Alllways try screwdriver first. If the pin doesn'y come out when you unscrewing it, that means you have pins instead. Use small steel pin and hammer to drive the pins out. Make sure that the split end comes out of the hole first.
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
