Buttons on control panel not working, remote control not working
Use the remote control and press the MENU button and select the OPTION with the UP and DOWN arrow buttons. Press ENTER button and then press UP and DOWN arrow button to select CONTROL PANEL use LEFT and RIGHT arrow button to VALID the control panel buttons
If you have a loss of the remote control while the control panel is invalidated.
Press and hold the MENU button for 2 seconds with pressing the ENTER button to enter the MENU and VALID the control panel.
Front Panel Lock
This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock
feature is ON, the TV operates with the remote control.
• To lock the buttons on the front of the TV, make sure the TV is turned ON, then press and
hold the ON•OFF button on the remote for approximately 5 seconds.
• To turn off the front panel lock, make sure the TV is OFF, then press and hold the
ON•OFF button on the remote for approximately 5 seconds. Now the buttons will operate
properly.
http://support.ttetech.com/RCATV/Assets/pdfs/E13320_1558177E_IB_e-02.pdf A manual for a similar model if you need it. Many of the controls should work the same. Good luck and please leave feedback!
