Microwave Ovens Logo
j
james corbett Posted on Jul 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the warming drawer sensor in my kitchenaid oven?
Electro Med Services
Level 3:
  • KitchenAid Master 6,694 Answers
  • Posted on Aug 16, 2016
KitchenAid Master
Level 3:
Answers
6694
Questions
Helped
1872425
Points
21433
If you wish to get some details about microwave oven repair and error codes then check the following link
http://electro-medical.blogspot.com/
1 Related Answer
Anonymous
  • 2605 Answers
  • Posted on Apr 10, 2011
SOURCE: Our KitchenAid Oven shows power
Hello, Welcome to FixYa. Can you could provide the model number that will help determine if it's a combo, gas, electric and avoid any generalizing with you machine. Another question I have that may go a long way in solving this problem is this, did this problem seem to start following a self clean of the oven ? You also mentioned the clock/timer (master control) has power going to it, but what about voltage coming out when you select either bake or broil ? I'll wait for you reply to see whats been done or suggested and checked to this point. Regards, Macmarkus :)
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
How to reset dacor mwo30s warming drawer
If for some reason you don't still have your owner's manual, you can find it here.
Thermador warming drawer takes 45 minutes to reach 190 degrees on high setting! That can't be right! Tech support said it should be 220 degrees on high and should take 20 minutes to fully heat.
I recommend that you go with your microwaves and claim to fix it. This can be a problem with magnetron, or power diode, capacitor faulty, or thermostat.
God bless you
1helpful
Micro pops and lites flash. i have a thermador combo oven warming drawer and micrwave.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
2helpful
Kitchenaid microwave khhs179lss-0 has error F3H
Hi, F3H mean that Humidity Sensor Failure. You have to refer to the Tech Sheet and test the sensor.
Our 2007 kitchenaid microwave, 1200 watts unit suddenly stopped working - it powers on as normal, but is not warming items as it should. Not sure what to do. Seems too new to kick the budket at this...
your wires going to the magnatron have probably have got loose and do not have a good connection, this is what I find on whirlpool/Kitchenaid microwaves
Kitchenaide microwave not heating - no stange noised, everying else seems to be working just no heat
there are few sensors inside that might go bad but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
4helpful
2answers
Fuse location on a KitchenAid Microwave
my kitchenaid microwave oven does not heat anymore
everything else works but it will not warm anything up
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
