I cannot watch DVD's because the progressive scan button is stuck. I have tried unplugging and pressing the stop button. Nothing has worked. Please help
The progressive scan light on the unit is on and I cant play any DVD's. The VCR works fine. I think if I can get the progressive light to go off then the DVD might work, but how do you do that? The progressive scan light on the unit is on and I cant play any DVD's. The VCR works fine. I think if I can get the progressive light to go off then the DVD might work, but how do you do that?
You can't post conmments that contain an email address.
press the set up button on the remote...the word "set up" should appear on the unit. then press and hold the stop button for 5 seconds...problem solved.
just talked to LG Customer support and got them to send me a manual.
to turn off the progressive scan insert a disk and once it starts playing press stop, then press stop again and hold for 5 seconds this will turn off the progressive scan mode.
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS.
Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk.
Try it & Good Luck!!!!!!!!
