2004 Nissan Maxima Logo
Posted on Jul 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power windows, sunroof, seats and door locks do not work
I have the same problem on my 2000 Maxima. I was moving the driver seat back and it stopped moving. Whatever happened seemed to take out the power windows, sunroof, both pwr seats and power door locks. However, the door locls worked for me yesterday twice, then stopped working and instead there was a clicking noise under the dash in a small plastic box the size of a deck of cards whenever I attempted to lock/unlock the doors. I checked the fuses...all were fine. Not sure were to go next.
kirtec auto
Level 3:
President:
  • Nissan Master 1,348 Answers
  • Posted on Jul 18, 2009
kirtec auto
Nissan Master
Level 3:
President:
Answers
1348
Questions
0
Helped
596158
Points
4360
That is the interior lights and alarm,remote module
1helpful
2answers
Front drivers seat will not slide back and forth.
No, check for a blockage in the seat track. You have one power source for all seat functions. If it works one way but not the others it is either a bad switch, or bad motor, or a blockage.
1helpful
My 2004 Maxima power windows, power locks, power sunroof all stopped working at the same time. Fuses all look good. Any suggestions?
does your power seat work?if not unbolt seat lift up and unplug connectors coming up from floor to seat.wait a couple minutes for internal circuit breaker in body control module to cool and reset and see if your other components start working.if so wiring in seat has grounded out to seat frame and sometimes se it crushed under metal seat pan below cushion.usually easy to insulate and repair once you find it.
3helpful
Sunroof will not work
Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
The RAP relay is responsible for the radio and windows working after the igntion is turned off.
The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
(7) Door Lock Relay
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2answers
Power seats on 2000 maxima not working
hello.
check fuse. if its ok. check for any upstickls underneath seat. Check also the wiring connectors underneath seat for bad connections. try moving the wires when adjusting seat. good luck.
2000 Blazer power seats
i dont thing there is something to do with the power seats when you blew an engine, plus the power locks too.
im thingking, when you put the engine, a lot of wires and fuse boxes are in the engine compartment, you could probably disconnect some wire that are on the way on changing the engine and forgot to put the wires back together.
that is the only thing i could think of..
i hope i answered your questions...
tnx
drcool
pls rate me...
No power to windows, power seat or sunroof
Yes, or it may the control unit may be defective you need check with the mech to solve the problem..................
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
