Health & Beauty Logo
Scott Marston Posted on Jul 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a Pride celebrity 3 wheeler mobility scooter,going at one speed when I press the button to go a higher speed it stays the same speed what is my problem? ?
Jeff Bird
Level 3:
  • Pride Master 1,348 Answers
  • Posted on Jul 28, 2016
Jeff Bird
Pride Master
Level 3:
Answers
1348
Questions
0
Helped
362849
Points
4615
Hi hard to diagnose the fault it could B you're speed potentiometer fast ,& slow knob on top also it could B the circuitry connected to the paddle :::: it could B a fault with you're computer control box .plus it could B a fault with the motor,...get in touch with ,....pridemobility.com phone. 1-800-800-8586 ..,,Cheers
2 Related Answers
Anonymous
  • 177 Answers
  • Posted on May 27, 2010
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
volunteer162
Specs Healthcare \ Avia Mobility
  • 90 Answers
  • Posted on Jan 04, 2012
SOURCE: instruction manual for pride mobility sonic & celebraity scooter
Here is the link to all pride manuals for power mobility.All files are .pdf and searchable.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
Why does my scooter stick in reverse when i push forward & stop when i push reverse
Hi, it could be that the throttle has turned around within the throttle lever therefore no longer centre, look under the throttle stem, you should see a cross head now that should be in align with you when sitting on the scooter...you will need to loosen the throttle and realign if that is the case...
Regards
Rob
www.gewizrepairs.co.uk
2helpful
Lost key to Pride Celebrity Scooter. Have an extra key for another Celebrity scooter. Are keys interchangeable? Thanks, DJ
DJ should work try it if all else fails call Pride @ 1-800-800-8586 ask for tech Support and ask to get a set of keys or You can replace the keyed switch with a on/off toggle switch Hope this helps
3helpful
PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
3 wheelers tip. Is there a stabilizing bar with 2
Hello, There is nothing available from the manufacterer or comercially for this type of scooter.
Some Scooters have Castor wheels underneath the edge of the footboards but they are usually have a higher ground clearence.
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
