Slide the PHONE up to reveal the keypad.
Type in your four to eight digit PIN and press "OK." If you have not set a UNIQUE PIN, enter the default PIN code that is set by your wireless carrier. (Normally "0000" or "1234.") If you receive an "Incorrect PIN" error, enter the default PIN twice more. "PIN Blocked" will be displayed.
Contact your wireless provider to request the unique Personal Unblocking Key for your device. In most cases, you will need to verify your wireless account information to obtain the code.
Type in the PUK code and press "OK."
Type in a new PIN code--the code can be four to eight digits. Press "OK." Re-enter your PIN to confirm and press "OK." The device is now unlocked.
Slide open the phone to reveal the keypad.
Enter in your four to eight digit lock code. If the code has not been altered, it will be "0000."
Press "OK."
in itunes, import the shared folder into the library.
it usually should be in
C:\Documents and Settings\Username\Shared
where "username" is your account name.
hope it helps.
