In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye. If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault. If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
You probably wont believe this but some DVD players aren't smart enough i had one like that in fact it was not working on the movies Underworld and the van helsing movie .
You might try using a RF Gainer walmart sells them install it as it comes out of the DVD player i hope this was some help if not you ll probably have to get a better line of DVD player i have a magnavox DVD/VHS daul recorder
You need to play DVDs through Acer Arcade. To do this you can turn off autoplay (use help function), or assign Acer Arcade to automatically play DVDs. If you still want to use Windows Media Player to play your DVDs you must uninstall Acer Arcade.
