SOURCE: engine oil light came on, on my mercedes ML 350, 2006 model.
IT MEANS THAT YOUR OIL LEVEL IS VERY LOW AND NEEDS TO BE FILLED. CHECK THE OIL LEVEL WITH THE DIPSTICK IF EQUIPPED. IF NOT, THEN ADD 1 OR 2 QUARTS OF OIL TO SEE IF THE OIL LIGHT GOES OFF. IT MAY TAKE SYNTHETIC OIL SO DON'T PUT CONVENTIONAL OIL IN IT IF YOU SEE A MOBIL 1 SYNTHETIC OIL RECOMMENDATION STICKER UNDER THE HOOD. IF YOU ARE UNSURE THEN BRING IT TO A QUALIFIED TECHNICIAN A.S.A.P.. HOPE THIS HELPS. GOOD LUCK.
SOURCE: need a diagram for serpentine belt replacement for mercedes benz
Below is a link for your diagram. Best of luck!
Greg
http://www.mvreader.com/multiview/dayco/zoom.php?zoom_item=C0002R&l=n&catalog=auto&category=2
SOURCE: how do i reset the clock in a ml350 mercedes benz
Press services ,left of screen,then system,right ofscreen
Use up/down/left/right on rotary button bottom right/screen
SOURCE: My low beam light bulb
well this is not easy unless you make a accessby removing anything in the way,or just take the headlight out ,How did you manage to open the bonnet as these vehicles from around this year started using a sealed bonnet that only the dealers can open with a special electronic key that uses rolling encrypted software.
SOURCE: reset service code B mercedes
Welcome to FIxYa.com
Reset Service Indicator
1. Insert key into ignition, switch to position "1". The mileage counter has to be
displayed.
2. Press repeatedly until the TRIP option is highlighted.
3. Press and hold and within 1 second press and hold both for 5
seconds. The shop menu is displayed.
4. Press repeatedly until "Assyst Plus" is highlighted and confirm with .
Options "Service Data" and "Full Service" are displayed.
5. Press until "Full Service" is highlighted. Confirm with .
6. Press until "Conf. Full Serv." is highlighted, confirm with . The display
shows "Service carried out?."
7. Press to select "Yes". Confirm with . "Cannot be undone" displays.
8. Press until "Confirm" is highlighted. Confirm by pressing . The display
reads "Full Service carried out".
9. Confirm by pressing .
MB
Regards, Lee Davidian
Thank you for using FixYa.com
