Question about JVC HD-52G886 52" Rear Projection HDTV
Cleaning the inside of the front screen
Projection TV model 52-G886. We knew there were a couple of dead bugs inside the screen, but now after remodeling the room we can see lines that float, assuming they are dust webs. Would like to know if anyone has been successful in cleaning this on their own. Thanks.
DEB and DAN B
  • 1 more comment
  • JettBoy Nov 19, 2007
    TV is a JVC HD-ILA
  • Ivan Johnson
    Ivan Johnson Dec 13, 2007
    to clean your screen,you take a small door off that is on the left side of your tv.Remove the screw that holds the door and slide the door towards the rear of the tv,unplug the tv and take a swifter duster with the extension handle.You can reach all the way accross the screen and clean the lense,That is the thing that looks like a glass ball,be carful not to damage anything.plug the tv in,and on,Repeat this if needed.You can spray some window cleaner on your swifter if you have smoke residue,you will have to cange yor swifter until you get clean(make sure everything is dry before turning on).
  • ms_toniecej Dec 21, 2008
    i have a jvc hd-52g886. where are the screws located to take the back panel off?
  • 203 Answers
It's not hard but is time consuming
You'll have to pull the front of the unit off to clean the inside. This includes taking out the screw that are open normally and there should be about 4 screws that are behind the bottom-back panel.
When you open the unit just be sure you get it clean the first time and don't leave any stray fingerprints on the glass. And don't touch the projection lens at all. Use compressed air to blow it off but I wouldn't recommend cleaning it unless it is just filthy and the canned air doesn't work for you.
Posted on Nov 19, 2007
6ya staff
SOURCE:
The front screen cover
The speaker cover just pulls off, there are 4 screws holding the screen on, take them out and the screen should lift off. But be careful, there are wires attached to it, so don't let it drop.
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Front screen
look on back of tv there is 25 screws remove them and the 5 on bootom in front of tv.
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
Front screen
Hi, much easier to access the front screens (there are 2 sandwiched together) by removing the top back cover, be prepared for lots of screws and when you get down to the last 2-3 screws get some help, on the inside of the back cover is a large mirror, some are made of mylar, do NOT clean or even touch a mylar mirror, the others are made of real glass and the back will be much heavier than you think (and very expensive if you break it)once the back is removed you should have access to the bug, good luck, video-tek
Bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Jan 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Wd 52525 52 in dlp tv screen needs cleaned
all you have to do is, take the 12 screws out from around the screen, from the back, there are also like 4 of them on the front, but usually , you can just lean the screen out far enough to use a swifer sweeper in there, and the dust isnt going to be on the back of the screen, it will be on the projecter, do the screen while the tv is on, then you will realy see the dust on the projecter
Jan 07, 2009 | Mitsubishi WD-52627 52" Television
RCA projector cleaning procedures?
Whatever you do you are better off to leave it alone or change coolant fluid in Tube its a Job doing it and you risk breaking Tube $450.00 unless you see the bugs in picture who cares.
Dec 28, 2008 | RCA D52W19 52" Rear Projection Television
Monitor strip down got a bug dead on inside of my screen
HOW CAN I REMOVE THE PROTECTION SCREEN TO CLEAN A DEAD BUG BETWEEN DE PROTECTOR AND SCREEN TV
Aug 11, 2008 | RCA HD52W59 HDTV Projection Television
Spider in my tv
no way to prevent....but screens will need removal and clean inside....aarons has service dept for this....good luck...
Jul 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA model P52927
Look, take out back cover and on the bottom left and right side you will see screw (2 or 4), take out it,Disconnect 2 plugs wire from chasis, pull out the box and you will have space for clean your screen.( You will take out all box with main chasis, convergence chasis )
Apr 22, 2008 | RCA P52926 52" Rear Projection Television
JVC HD-52G886 52" Rear Projection HDTV Logo
415 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
