Chair was made in August 1998.the motor part number is 1070505 or 1070506
Gerald,
For the 2 pole Invacare motors 1070505 and 1070506, the Invacare website gives the following:
brushes with caps(pair) part #1064336
See the link below for assembly and part numbers
I hope this helps. There is an excellent company Eurton Electric which specializes in rebuilding these motors which are no longer available.
http://www.invacare.com/parts/assembly/12083.pdf
Testimonial: "Thank you.I was on the right track but hearing from an expert I feel alot better.I think I'll try rebuilders of these motors and see what they use.I'll let you know what I find out.Thanks again"
SOURCE: sourcing motor brushes for E675 jazzy motor?
Hi Lane - here is a link to a few sources for carbon brushes. http://www.pronto.com/user/search.do?displayQuery=brushes%20for%20motors&SEM=true&query=brushes%20for%20motors&adid=s-20070803-64608-85461_gs&ref=brushes%20for%20motors&creativeid=3500605965&site=
please rate my answer as very helpful. thanks Jo
Hi Lane. What happened to your old brushes?
Be carefull fitting different brushes to your machine. If you do, make sure that the brushes you use are also for a 24 volt DC motor. Different voltage motors have different types of material used for the brushes, they can damsge your commutator if you use the wrong ones.
If you find some that are slightly to big, it is Ok to carefully file them down to size.
Contact a local service agent, they often have used brushes that still have a bit of life in them.
I often use brushes from one brand in other brands of machine, and have used brushes as well, but we are probably too far away in New Zealand.
Good luck. Neil.
