Dryers Logo
Cindy Rowe Webber Posted on Jul 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I hook up external plug to this dryer how do the wires go.
Steven Clarke
Level 2:
Sergeant:
  • Expert 222 Answers
  • Posted on Jul 24, 2016
Steven Clarke
Expert
Level 2:
Sergeant:
Answers
222
Questions
0
Helped
141489
Points
567
Red on left white in center black on right green (if it has one) connects to the cabinet or in some instances to the center.
3helpful
2answers
We were never given an owner's manual for our
Hi wildspiritmo...
Go to the following webpage and see pictures and discription of how to change you 3 wire dryer into a 4 wire dryer.
Please take time to rate me thumbs up
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
1helpful
How do i hook up a 4 post plug to a 3 post plug
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
How does a 4 wire plug hook to the back of a whirlpool cabrio dryer
heatman101
I moved into a house that has the 4 prong dryer receptacle and I bought the new 4 prong plug to hook up to my dryer but there are only 3 wires on my old one. The new one has a red, green, white and a black...
be careful the voltage may be different thats why they make them with different plug configurations. check your dryer voltage requirement. usually the four wire type are for 250vac electric dryers.
Mar 06, 2010 • Dryers
8helpful
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
External speaker connection problem
you will have to solder a female plug to those wires then you will be able to plug in a 1/4th male plug from your speaker wires
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Top Dryers Experts
john h
