Partial Answer (maybe)
If you mean that the Slides do not advance when you push the remote then You have the same problem I encountered on my Rollei P350A. I opened the projector and found that the Drive Belt between the motor and the Slide changing mechanism was broken. I actually found the black broken string in the Projector case. I did not fix my projector yet since I am looking for a replacement Drive Belt (posted question above a little while ago)
SOURCE: Rollei 66 Dul P projector
I've only worked on one or two of those, with no training in that brand. Good machines but I suggest you try an authorised service shop. here are some links to try
http://www.sl66.com/pg/repair.shtml
In Canada, this company *might* be able to help you. Kominek
405 Yonge St
Toronto ON, M5B 1S9
Phone: 416-977-2132
SOURCE: rollei slide projector
you need to go to a photo shop (not walmart). but you may need the negatives.
SOURCE: Kodak 750H corousel slide projector
Chances are, by your description (and my estimate of the age of this model of projector), that you have a broken solenoid "link". The "link" connects the cycle solenoid and the slide change mechanism. The "link" is made of plastic, and gets brittle & cracks over time. This is a difficult repair, but you should still be able to find parts available. My advice is have this repair done by a factory-trained repair dealer and your projector will run another 20 years.
SOURCE: Can slide cartridges be interchanged
the Rollei projector use a europian strait tray this is a standard tray used by many manufactures.
SOURCE: We have a Kodak Carousel
I suspect the problem you have is a stretched drive belt (from the power motor to the slide change mechanism). The good news is there are still parts available from: www.micro-tools.com The problem is the replacement of this belt is a involved disassembly - at the very least you would need great mechanical aptitude and (most important) a service manual. I would recommend locating a factory-trained service dealer to make this repair for you.
Good Luck !
