I can t get into my phone as it will not turn on (charging light not on) and it won t charge. I have no security locks on it.
SOURCE: Orange light when I charge my MotoRokr E8!
Kevin you must try charging it with the wall-charger, if that doesn't works, try entering BL mode by pressing # and *, and then pull the trigger to turn it on.
It will tell you that battery is low, you can connect then the charger, pull the trigger again, it should start normally.
SOURCE: my iphone wont turn on or charge!!
That happened to me. Push the home and on/off buttons simultaneously until the apple logo appears, then wait until it has fully restored the system. This should work. Good luck
SOURCE: blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
SOURCE: please i have a
try this number 12345. Cos' it's the default code that are provided by Nokia Company. If not you need to refer to the nearest mobile service centre.
Thanks for using FixYa
Testimonial: "yes.thank you so much"
SOURCE: alcatel phone sim card locked
What is Mobile Phone Model? If the Phone says Sim locked means ,you need to unlock it...You can get the free Unlock code for Alcatel Old Phones at here Unlock-free.com/alcatel/ and unlock it from Sim network lock.
