What type of oil/lubricant goes in crank case above axle?
Manual available on scribed at: https://www.scribd.com/document/381849057/6070S-Manual1
Normal engine oil in the engine sump
gear oil 80 oep in the gear box
SOURCE: What type oil goes in the tranmission?
80W90 Gear oil goes in the tranny. 30W is for the engine only,
SOURCE: Where is the model number on my troybilt rear tine tiller?
If it's as old as mine (circa 1976), it's stamped on the casting right below the T-handle that allows the handle bars to pivot (also the gear case fill cap)
SOURCE: I have a Scotts TurfMaster Gear Drive
Your worm shaft or tine shaft and gear assembly are probably shot. Welcome to the club. Long live American manufacturing.
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
SOURCE: what size are the belts on the ardisam scotts
looking for a forward belt for a Scott model 6070s tiller
