Cell Phones Logo
M
Mandy Pullen Posted on Jul 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do u tell which model KYOCERA HYDRO AIR that you have?I only see that name no model #..help
I purchased in march 2016.just now trying to use & set up, lost manuel..I have the warrenty guide w name & original store recipt..how do I go about getting a how to use manuel
bigdawg7299
Level 3:
  • Master 2,559 Answers
  • Posted on Jul 21, 2016
bigdawg7299
Master
Level 3:
Answers
2559
Questions
0
Helped
556902
Points
7776
Https://www.kyoceramobile.com/hydro-air/Hydro-AIR-User-Guide-ATT_en.pdf
1helpful
2answers
Need to get at&t off unlocked now t-mobile
24x7unlockcodes.com is the right place to unlock your At&t Kyocera Hydro Air. You may need this when you are switching your sim card for change your network or visiting abroad. You can get your unlocked permanently by our hassle-free procedure in a competitive price online at your door step!!! Just order us & relax at your home, we e-mailed you once it done.
Use of unlock code for At&t Kyocera Hydro Air network unlocking is totally legal. We insured you that our service will not change any feature or behavior of your At&t Kyocera Hydro Air. The data in your At&t Kyocera Hydro Air will also remain protected.
Under circumstances like, If the code will not successfully derived by us or will not work on your Device, we guarantee our customer fully refund of their money.
For Permanent Motorola At&t Kyocera Hydro Air Network Unlocking
https://24x7unlockcodes.com/product/any-kyocera-unlock-code
For Permanent LG Sim Network Unlock PIN
https://24x7unlockcodes.com/brand/lg
For Permanent Samsung IMEI Unlock Code
https://24x7unlockcodes.com/brand/samsung
Best Sim Network Unlock Pin Provider
24x7UnlockCode Network Unlock Code IMEI Unlock Code Unlock Code
How do I hard factory reset my kyocera hydro air
a factory reset will loose all your data
nice phone
try this link a 95 page pdf should have an answer
page 85
Factory Data Reset 1. From the Home screen, tap Apps > Settings > Backup & reset. 2. Tap Factory data reset. 3. Read the factory data reset information, select the Erase SD card check box if necessary, and tap RESET PHONE. 4. Tap ERASE EVERYTHING. Note: The deleted data CANNOT be retrieved.
https://www.kyoceramobile.com/hydro-air/Hydro-AIR-User-Guide-ATT_en.pdf
1helpful
I have a Kyocera Hydro and my Google play app is stopped. How do I fix it?
oogle play services has stopped - Google Product Forums
productforums.google.com/d/topic/play/ogWU42sBkOw
Google
Sep 10, 2015 - 27 posts - ‎18 authors
Check your apps from Google Play Store > My Apps or Application Manager list. ...My phone details: Kyocera Hydro Vibe model C6725.
Kyocera Phone Apps Crash - FreedomPop Forums
forums.freedompop.com > ... > Kyocera Hydro Icon
Sep 20, 2015 - Hi, @Jorge M. @admin I have 2 Kyocera Hydro Icons, and they both have this issue. ... Ever since I updated the apps/and Google Play services, whenever I open up an .... once I reverted back to the stock version everything stopped crashing. ... And how can I back up my apps/settings if I were to do that? 0. Kyocera Hydro Icon Fix Till Google & Kyocera Give the Proper ...
Nov 16, 2015
Tethering on FP Phones and Google Play Services Crashing ...
Nov 7, 2015
More results from forums.freedompop.com
Google Play Services not Working :( ' Page 2 ' Android Forums
androidforums.com > Android Phones > Kyocera Hydro Vibe
1helpful
Need manual for model ID#V65c5215
If V65C5215 is the F.C.C. I.D. of the cell phone, then you need the manual for the Kyocera Hydro EDGE. The manual is available from the manufacturer's product page: https://www.kyoceramobile.com/hydro-edge/ . Scroll down to the Hydro Edge in-depth section and select the manual for your carrier. The direct link to the manual for the phone from Sprint is https://www.kyoceramobile.com/hydro-edge/Hydro_EDGE_User_Guide_Sprint_en.pdf . For Boost Mobile, try https://www.kyoceramobile.com/hydro-edge/Hydro_EDGE_User_Guide_Boost_en.pdf .
I hope this helps.
How do I find and locate a user manual for my Kyocera Hydro Edge ??
http://www.phonearena.com/phones/Kyocera-Hydro-EDGE_id7865/manual
1helpful
What is the unlocking code for a Kyocera Hydro Life..model #6035?
Resetting the phone If the phone does not respond to taps or key presses with the flip either
open or closed, you may need to perform a reset.
There are two types of resets-soft resets and hard resets. In a soft reset,
all records and entries are saved. In a hard reset, all records and entries
are erased. If you must do a hard reset, you can restore any data that you
previously synchronized using a HotSync operation.
To perform a soft reset
May be either on or off
Open
1. Turn the Kyocera smartphone over. Open
the battery door on the back of the phone.
2. Press the reset button with the stylus.
3. Replace the battery door. Turn the phone
back over and verify that it has restarted.
Top Kyocera Cell Phones Experts
Jim LeVerso - IT...
Jim LeVerso - IT...
john h
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
