SOURCE: Navman f10
my navmanscreen went black now it shows a computer screen with anavman on other side with x on it could you help my email adress is [email protected] thankyou
SOURCE: Screen is showing computer, usb
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
SOURCE: Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
SOURCE: when I try to update my navman It says I'm not connected and I am?
Hi - yes it probably is a driver thing. Navman's install software apparently doesn't install the Windows driver - you have to do it manually.
I just found this how-to page on Navman's website, and it worked for me:
http://www.support.navman-europe.com/FAQs/Drivers/F-Series/
Good luck
Peter
SOURCE: Navman model no N197 -
Base from the description of your problem what we need to do here is to reset your unit and to do that follow this , there is a small hole at the back of the unit (from memory, but might be on the top) just use a pen to press and hold it for 10 seconds and then restart the unit and check if its back to original state.
