My navman move 60LM says it is critical with battery so have taken and plugged into computer and tried power point thru usb but all it does is flash the screen what is going on iwth it please
Try to connect it to a computer usb and see if it is recognized . Flashing when you push power button means battery is not charged . Flashing all the time when plugged to the power source means it is charging . Try another power cable or check your power input on your multipad - try to move it with toothpick or a pen and see if it is loose or not .
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
If the battery isn't too far gone, here's how to revive it: Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours. Be sure the charging light is lit -- sometimes a drained Kindle will stop charging a few seconds after you plug it in. Unplug and replug until the light stays on steadily, then leave it alone. Most of the time you'll come back to a restored Kindle. If not, go on to step 2. If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds. Release the power slide, then immediately press and hold the Home key for another 30 - 45 seconds. Once the Kindle's screen begins to flash, release the Home key. The eReader will boot to recovery mode. To continue, press and hold the R key until the screen flashes again. After the device is finished rebooting, you may see the Critical Battery screen once more. If so, plug in the USB cord and wait for the Kindle to return to the Home screen. - See more at: http://www.laptopmag.com/articles/kindle-critical-battery-error#sthash.Rtxwp4El.dpuf
Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
Plug the unit into its charger using the USB port on the
bottom of the unit. The battery indicator light next to the power switch
should turn orange, indicating that the device is charging. Once the
light has turned green the charge is complete. If the light does not
turn on, verify that the car charger is plugged into a working outlet.
The mac computer should be able to read your Windows partition, but be warned that it will not work the other way around. There are many ways of moving the file, such as copying to a flash drive and plugging the flash drive into the Mac computer, or e-mailing the file to yourself.
oooooohh..ok..remove the battery..let it chill for a few and then try it again..I understand that you are to only plug that unit into a usb, when it's powered down.
The problem is that most of the chargers have the output of 5V/0.5A. The charger for NAVMAN (C30 in my case) has 5V/1A. And that is causing the trouble. The GPS is undercharged and is switching off itself. Buy one which specify the output power: 5V/1A.
Hope I solved your problem
link to manual not there Ron sorry
